2004 Ford F150 Charging problem.
2004 FORD F-150
JOHNLUNDRIGAN
Electrical problem
2004 Ford F150 V8 Four Wheel Drive Automatic 120k miles
I have a 2004 F-150. I was driving it when the battery light came on. After a while i saw the voltage meter drop quickly and when i shut off truck battery was dead. If i charged battery with cables truck would run off battery until charge ran out. Replaced alternator, problem seemed fixed but light remained on. While driving on highway 1000 k later saw needle dropping while i was at low rpm. Got truck to 3000 rpm needle returned to normal. About 3000k later same thing happened and needle again shot back up but only when i put rpm to 3000. If voltage needle drops and i don't hit 3000 rpm truck will die. I can keep truck charged by pulling over and hitting high rpms, as soon as i hit 3000 rpm needle returns and stays at normal. Please help
Aug 23, 2010 at 4:59 PM
  • 110,240 POSTS
I would start by having the alt and regulator rechecked. If that is good, then I would start checking fuseable links between the alt and the battery.
Aug 24, 2010 at 2:21 PM
