2004 Ford F150 Air/Idle sensor ?
89,000 MILES • V8 • 2WD • AUTOMATIC
DUFFBALL
When slowing down and/or almost at a complete stop, typically while turning, the rpms drop to less than half of 1 rpm and the truck dies. When driving on the open road/highway, everything is fine. Please advise !!
Jun 18, 2008 at 3:22 AM
2CARPRO JACK
  • 11,533 POSTS
Most likely the Idle AIr control valve, replaced a ton of them on Fords and they dont ususally set the check engine light
Jun 18, 2008 at 3:36 AM
DUFFBALL
[quote:3904ea3fdf="2CarPro Jack"]Most likely the Idle AIr control valve, replaced a ton of them on Fords and they dont ususally set the check engine light[/quote:3904ea3fdf]
Is this something the average guy can change or is it worth taking to a mechanic ?
Jun 18, 2008 at 3:48 AM
MERLIN2021
  • 17,250 POSTS
It's located on the side of the throttlebody, with two screws, very simple, just don't mess up the new gasket!
https://images.2carpros.com/forum/automotive_pictures/62217_IAC_5.jpg
Jun 18, 2008 at 6:09 AM
