2004 Ford F150 ABOUT CLEANING THE THROTTLE BODY BUTTERFLY
50 MILES • V8 • 2WD • AUTOMATIC
MARKMOSS77
GREETINGS!
I was wanting to do an induction service on my 2004 4.6 ford f-150. i have been told 2 diffrent sides and wanted to see if you guys could help , i was going to manually open the big (main) induction butterfly and clean it with sensor safe cleaner ,if i open this by hand will it affect the "drive by wire " since i have no actaul throttle cable?will it affect the computer? will i have to buy the ford quoted $325 part ? or am i safe to do it once?
Apr 21, 2008 at 9:14 AM
MERLIN2021
  • 17,250 POSTS
First off, Fords use teflon on thier throttles, a wet rag is all you need, anything else could damage the teflon coating, and cause corrosion!
Apr 21, 2008 at 9:37 AM
