2004 Ford F150 4.6 L rough on startup
2004 FORD F-150
DCHEEKS
Engine Performance problem
2004 Ford F150 V8 Four Wheel Drive Automatic
Vehicle is rough on first startup for the day. upon acceleration a puff of black smoke is visible from exhaust. No code shown when hooked to diagnostic computer
Jul 2, 2009 at 12:18 PM
Running rich:
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
Jul 2, 2009 at 12:38 PM
