2004 Ford F150
84,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOSESOUSA
I WAS TOLD I NEED TO REPLACE ALL FOUR OF THE HO2 SENSORS IN MY TRUCK. IS IT POSSIBLE FOR ME TO DO IT MYSELF SINCE I DO ALL MY MAINTENANCE AND IS IT LIKELY THAT ALL FOUR WENT BAD?
Jan 22, 2008 at 2:06 AM
MERLIN2021
  • 17,250 POSTS
Is your check engine light on? what code(s) come up during the scan? 02 Sensors are only recommended 50,000 mile change, if you have no drivabilty concerns, why would you change them?
Jan 22, 2008 at 2:10 AM
JOSESOUSA
I WAS GIVENS CODE #S:p1131 & p1151.does this help?
Jan 22, 2008 at 2:28 AM
MERLIN2021
  • 17,250 POSTS
Those are codes for the upstream sensors only, they are the first sensors from the engine. Which 6 do you have 3.0 or 4.0? Could be a vacuum leak problem if it's 4.0, check with a can of gumout spray, spray the vac lines and maniflod area, when the idle changes, youve found the leak! You want the engine running and spray on the outside but do direct the stream onto the hoses, if it is a vacuum leak, the engine idle will change speed, then you have detected a leak, repair the vacuum leak and see how it runs! If you find no leaks replace the two front sensors, one on each side...
Jan 22, 2008 at 2:33 AM
