2004 Ford F-150 I've been told the condensor needs to be ch
37,500 MILES • V8 • 4WD • AUTOMATIC
JELABEDI
How tough is it to do this? I've looked at a picture of a condensor and it looks like there are just 2 connectors-the 1/2" female & 1/2" male. Also, I found 2 different models of condensor. How do I know which one to buy?
Oct 25, 2010 at 12:04 PM
CJ MEDEVAC
  • 11,000 POSTS
I searched 2 auto stores online,
The only engine info I had for you was "V-8" so I had 3 choices to use, I went with 5.4 Liter (the most common) this may be the problem with the 1st link.
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/PartSearchCmd?storeId=10151&catalogId=10051&langId=-1&pageId=partTypeList&suggestion=&actionSrc=Form&searchTerm=condenser
Heres the 2nd, using only the info I had, (1 Choice)
http://www.autozone.com/autozone/parts/2004-Ford-F150-1-2-ton-P-U-4WD/A-C-Condenser/_/N-jm42cZ9pd8u
You might also try NAPA, it is a good site to check.
Did any of this help, Imma Jeep CJ guy, just trying to assist you.
The Medic
Oct 26, 2010 at 2:09 AM
