2003 Ford F150 won't shift or run right
115,000 MILES • V8 • 4WD • AUTOMATIC
COBRA9372
truck wont run right, it act's like it's running out of gas . if you let it set it will go but wont shift, thought it was transmission .. bought new one, was not the problem ... and light on gearshifter the overdrive button light flashes ... it showed 12 error codes .... P0443
,P1451 , P1747, P0750 , P0755 , P0743 ,P0135, P0141 , P0155 , P0161 , P0403 , P1132
Jul 17, 2008 at 12:20 PM
BMRFIXIT
  • 19,053 POSTS
check the fuses
check for any missing fuses too
I would start with the fuses and move on to the wiring harness
Jul 18, 2008 at 11:08 PM
