2003 Ford F150 vibration
95,000 MILES • V8 • 4WD • AUTOMATIC
CHIPPER110
I suddenly have a terrible vibration at speeds above 50mph. I feel it in the steering wheel and gas pedal and can hear it. It seems to vibrate less when I let off the gas. I had a little play in one wheel bearing so I changed it but it did not help. The other wheel bearing is fairly new also. The tires don't appear to be worn, they are less than a year old. Any ideas?
thanks
Chad Reynolds
Jan 2, 2008 at 6:59 AM
  • 31,937 POSTS
Hi there,
Thank you for your donation,
Vibration through the steering will be front wheel balance, faulty tyre, and to a lesser extent steering components, loose, worn, rack or box, faulty tie rod ens and wheel bearings, i would be checking tyres for out of round and balance problem,
Mark (mhpautos)
Jan 2, 2008 at 11:00 AM
