2003 Ford F150 Turn singles
84,000 MILES • 6 CYL • 2WD • AUTOMATIC
MRDAD726
My turn singles just stoped working. If i put on the flishers all the lights work but the left frount. The only way the blinker will work is to hold back on the passing high beam while turnning on the right or left blinker. All of the bulbs and fuses are good. is there something elese i can check.
Jun 30, 2010 at 6:55 AM
BLUELIGHTNIN6
  • 16,542 POSTS
seems like either wiring issues at the signal marker left front, or the turn signal switch on steering column is faulty.
Jun 30, 2010 at 6:58 AM
