2003 Ford F150 R and R Ignition coils
103,000 MILES • V8 • 4WD • AUTOMATIC
JHDREAM
How do you remove and replace the 8 ignition coils for this truck
Jan 31, 2010 at 5:00 AM
  • 75,988 POSTS
REMOVAL:
https://images.2carpros.com/forum/automotive_pictures/12900_ic1_1.gif
1.Disconnect the Coil On Plug (COP) electrical connectors. 2.Disconnect the eight fuel injector electrical connectors.
https://images.2carpros.com/forum/automotive_pictures/12900_ic2_1.gif
3.Remove the bolts and ignition coils. INSTALLATION: 1.To install, reverse the removal procedure. NOTE: Apply brake caliper grease to the inside of the coil boots.
Jan 31, 2010 at 10:56 AM
