2003 Ford F150 No spark to engine
36,000 MILES • 6 CYL • 2WD • AUTOMATIC
JACK65274
I replace by dead engine with a used engine that has 36,000 miles. The change out went pretty smoothly but now the engine wont start. Seems to be getting fuel. I tested the spark with an ignition tester and there is no spark from the coil. I have already replace the coil as I had a new one from the old engine. Im guessing the next step is to locate and check the proper sensor?
Mar 7, 2010 at 5:40 AM
BILLYMAC
  • 2,204 POSTS
i would check all the grounds and all the fuses and the crank sensor
Mar 7, 2010 at 12:36 PM
