I replace by dead engine with a used engine that has 36,000 miles. The change out went pretty smoothly but now the engine wont start. Seems to be getting fuel. I tested the spark with an ignition tester and there is no spark from the coil. I have already replace the coil as I had a new one from the old engine. Im guessing the next step is to locate and check the proper sensor?
Mar 7, 2010 at 5:40 AM
