2003 Ford F150 My clutch got stuck
DMRAMSES
Transmission problem
2003 Ford F150 6 cyl Two Wheel Drive Manual 90K miles
this morning I truned on the truck with no problems but when I pressed the clutch and put in the firts gear, the clutch lost pressure. it seems to be stuck to the bottom of the pedal. I pressed it again repeatedly but was unable to get it to work. How can I get it to work or what is the problem?
Nov 23, 2009 at 1:38 AM
  • 110,248 POSTS
It sounds like the slave cylender for the clutch is bad. Have that checked.
Nov 23, 2009 at 5:36 AM
