My F150 is making an loud ernt-enrt-ernt noise when it's running. The noise is intermittent, and happens more when it's cold outside, the engine is cold, or when I change from running the AC to vent. The engine isn't robbed of power and the RPMs do not change when it happens. I have cleaned the MAS sensor, and replaced the air filter based on someone thinking it might be backfiring into the air intake. I have tried to localize where the noise is coming from and it seems to be coming from the driver's side right above or next the wheel well in the engine compartment.
Jul 30, 2008 at 3:27 AM
