2003 Ford F150 loss of compression
2003 FORD F-150
DONNLLBOYD
Engine Performance problem
2003 Ford F150 6 cyl Two Wheel Drive Manual
while driving i increase speed the engine loses compression or power
Dec 5, 2009 at 6:16 AM
  • 110,240 POSTS
The first thing I would check would be the catylatic converter to make sure it isn't plugged. Check it at night after driving to see if it is glowing red hot. IF it is, it's plugged. If things appear ok there, move to the fuel pump pressure.
LEt me know about the converter. We'll move on if that appears okay.
Dec 5, 2009 at 8:15 AM
