These are the trouble codes: P0125, P0171, and P0174.
I have replaced the fuel filter, O2 sensors, cleaned the MAF, and checked for air leaks on intake (however, not sure if I missed some). The problem usually arises when I give her some gas. Then the exhaust rumbles and the power is not supplied to the vehicle (acceleration). It seems that there is too much oxygen being supplied hence the improper combustion and hesitation/lack of power. I can't figure out why though. After doing research I'm guessing it's the MAF, iat sensor, temp gauge, EGR valve, or a gasket.
Mar 30, 2009 at 11:00 AM
