Electronic climate control unit. Heater is currently only blowing on defrost. A/C works good on vents, floor and defrost. Heater will not blow on floor. I replaced the heater unit once and it worked ok for about 6 months, but then defaulted to the same defroster setting only. Is this a vacuum leak or did the ECU fail again? I now have 2 suspect failed heater units... are these repairable? If it's a vacuum leak, where should I start looking?
Jun 20, 2010 at 4:58 PM
