2003 Ford F150 Have to pump clutch pedal occasionaly to shi
63,000 MILES • V8 • 2WD • MANUAL
SKERWATH
I occasionaly have to pump my clutch pedal to feel any pressure and shift. I seems to do it more on hot days or on start up when the A/C is on. It's intermittent, so I have no idea where to start to look for the problem. The fluid in the mastercylinder is clear and full. I have never seen a puddle under the truck that could be hydraulic fluid. Usually 2 or 3 pumps and the clutch will disengage, but it comes and goes.
Aug 3, 2009 at 1:56 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Try bleeding clutch hydraulics at the slave maybe air in system.
Thanks for donate
Aug 3, 2009 at 5:31 AM
