2003 Ford F150 fuel pump issue
85,000 MILES • V8 • 2WD • AUTOMATIC
STEVE ELKINS
I have run my F-150 out of gas before and all I had to do was replace the 30A fuse under the dash luckily.Now I have run my truck out of gas again and it blows the fuse immediatly after turning the key to start.I cant check for pressure nor can I hear the pump run because the fuse blows immediatly.I think the pump is locked up.What do you think?Thank You.
Oct 24, 2009 at 2:51 AM
JDL
  • 16,098 POSTS
Welcome to the forum, are you saying the fuse blows before you turn on the key? The 30 amp fuse, I looked at was for the ignition coils and coil side of pcm relay. The fuse circuit goes hot when you turn on the key. Possible problem with a coil??
Oct 24, 2009 at 3:12 AM
