2003 Ford F150 Code P1131 and P1151
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
JKD2307
while stopped and idling for a period of 2 minute or more the truck begins to run rough and the check engine light comes on. once i accelerate, the truck runs fine until stopped for another 2 minutes or so. the check engine light will clear once the battery is disconnected, but will return once idling for a period. Took the truck to get the codes read and p1131 and p1151 are the two codes that came up.
Mar 15, 2009 at 1:36 PM
MIKE H R
  • 3,094 POSTS
the 1131 indicates ho2 indicator running lean, the 1151 is a o2 sensor circuit signal is intermedient. Check the wiring connections.
Mar 19, 2009 at 2:26 AM
