Hello, & Happy New Year:
I recently purchased an'03 F-150 Harley with a bad motor (truck has less than 10,000 mi. but motor was locked up). In moving truck around brakes worked good (hard pedal of course = no vacuum), but brakes worked & released good. Installed new motor, got everything running good so I decided to see if it would move itself, & brakes won't release. After lots of trying different things we figured out that as soon as the engine starts the pedal goes down & stays (holding brakes on). If I un-plug vacuum line to booster brakes release instantly (with or without motor running).
Can someone tell me if this is a bad booster or could it be in the ABS pump?
Thanks
Old generation Hot Rodder trying to play wit new generation toys.
Thanks
Dec 31, 2008 at 1:32 PM
