2003 Ford F150 Bad smell from heater, just replaced the cor
DJAMESATL
Heater problem
2003 Ford F150 V8 Four Wheel Drive Automatic 50k miles
I just replaced the heater core but the bad smell is still coming when I turn the heater on. the temp setting doesn't matter.
Dec 21, 2008 at 8:52 AM
BLACKOP555
  • 10,386 POSTS
can you describe the smell? and have you replaced the heater core due to leakage?
Dec 24, 2008 at 3:19 AM
DJAMESATL
I replaced the heater core and the thermistat so that's all fine now. The smell is a antifreeze smell and I figure that the leaked out fluid was despearsed through out the air ducts by the fan. I only cleaned the core box. I would like to know a remedy to remove the smell coming from the left over antifreeze in the ducts.
I have removed the heater fan resistor and sprayed deoderizer into the hole. It helped some but it still smells. The only thing I can think to do is spray more. Any help would be great. Thank you, Dennis
Dec 24, 2008 at 5:08 AM
BLACKOP555
  • 10,386 POSTS
hot water and bleach in a spray bottle. spray that in the vents should clean the smell right up!
also if you have a cabin air filter check that.
Dec 24, 2008 at 9:34 AM
