2003 Ford F150 Adding a Tachometer
2003 FORD F-150
74,000 MILES • V8 • 4WD • MANUAL
RANLPORT
Purchased truck with standard transmission but dash has no tachometer. Truck is in very good condition and quiet so much that it is hard to hear the engine as I start out and have almost stalled it. My question is which pin on the PCM should I hook up the tach wire to? I did hook to pin #48 but it doesn't work. I of course hooked up the hot and ground wires.
Sep 7, 2010 at 6:59 AM
MATTHEW.ADELMAN
  • 6 POSTS
I'm not very familiar with the newer F-150s, are you sure it's supposed to be connected to the PCM, most tachometers are connected to the ignition coil wiring harness. Double check the installation instructions.
Sep 11, 2010 at 8:17 AM
