Using either the AC or the Blower the vents switch from panel to defrost.
Sep 1, 2010 at 7:51 PM
✓Experienced Mechanic
You are looking for a vacuum leak in this case. Check under the dash first. If you are really lucky, you may hear a hissing sound with the engine running.
