2003 Ford F150 AC & Blower Switching from Panel to Defr
100,000 MILES • V8 • 4WD • AUTOMATIC
CCRAIN33
Using either the AC or the Blower the vents switch from panel to defrost.
Sep 1, 2010 at 7:51 PM
  • 110,246 POSTS
You are looking for a vacuum leak in this case. Check under the dash first. If you are really lucky, you may hear a hissing sound with the engine running.
Sep 1, 2010 at 11:57 PM
