2003 Ford F150 4 WHEEL DRIVE
16,600 MILES • V8 • 4WD • AUTOMATIC
RCURNEW
WHEN I TURN BUTTON TO 4 WHEEL IT LIGHTS UP ON DASH BOARD BUT WON'T GO INTO 4 WHEEL HIGH OR LOW. WENT TO USE TRUCK ON BEACH BUT GOT STUCK.
THANK YOU
RAY
Nov 15, 2009 at 8:36 AM
  • 110,248 POSTS
Chances are there is a problem with the actuator. It is the electrical motor on the transfer case that shifts it for you. First, check to see if you are getting power to it. If you are, remove the actuator and have it checked. Most likely it is bad.
Let me know what you find.
Nov 16, 2009 at 2:03 PM
