2003 Ford F-150
PWHOSEK
2003 Ford F-150 V8 Four Wheel Drive
remove front door panel on 2003 ford f150 extended cab.
Oct 10, 2010 at 3:27 PM
  • 110,248 POSTS
There are a few screws and clips that hold it in place. Check under the plastic plugs for the screws. If you have PW and Locks, the panel will need removed (clipped in) and there are clips between the panel and door holding it in place.
Oct 11, 2010 at 1:53 AM
