2002 Ford F150 Why battery light is On
187,000 MILES • 6 CYL • 2WD • AUTOMATIC
NOVA5966
Hi, I had a mechanic check why the battery light stays on and says that it may be the alternator or battery but both are working fine. Can you please help. Thanks.
Mar 12, 2008 at 10:53 AM
  • 75,988 POSTS
The light is coming On bcuz there's a problem within the charging system-check all fuses below then comeback
https://images.2carpros.com/forum/automotive_pictures/12900_fuses_1.jpg
Mar 12, 2008 at 11:05 AM
