2002 Ford F150 Torque Converter Solenoid
2002 FORD F-150
95,000 MILES • 6 CYL • 4WD • AUTOMATIC
BLUEFOXFIVE
My check engine light came on and I went to a local parts store to have them check it. The code said that the problem was the torque converter solenoid and the torque converter solenoid harness. Question one is could this problem cause the truck to stall when slowing down? Question two, I am a novice mechanic out of necessity. Should I go and try to fix this myself? From my understanding from talking to people is that all you have to do is change it out when you are changing the tranny oil. Is that so?
May 25, 2008 at 10:35 AM
LEGITIMATE007
  • 5,121 POSTS
you are absolutely correct in all aspects. it can cause your truck to stall, but also the idle air control valve can do this too , but yes you are correct. and why not try to change it your self
Jun 17, 2008 at 3:54 PM
