2002 Ford F-150 Ticking Noise
ANDYSKI2
  • 2002 FORD F-150
  • 6 CYL
  • MANUAL
  • 125,000 MILES
I recently repalced the clutch, Throw out bearing and pressure plate about 5000 miles ago. In the past few weeks I have noticed at idle when warm and the truck in nuetral (clutch not depressed) that I can hear a ticking noise. Once I depress the clutch the noise goes away.
Any thoughts
Friday, February 26th, 2010 AT 10:25 AM
MMPRINCE4000
  • 8,548 POSTS
The following possibilities.
Broken Throw-Out Lever Return Spring. Replace Return Spring.
Faulty Throw-Out Bearing. Replace Throw-Out Bearing.
Faulty Clutch Disc. Replace Clutch Disc
Faulty Pilot Bearing. Replace Pilot Bearing
Worn Throw-Out Bearing. Replace Throw-Out Bearing.
Dry Bearing Retainer Slide For Throw-Out Bearing Sleeve. Lubricate Slide
Friday, February 26th, 2010 AT 11:46 AM
