2002 Ford F-150 skips between 40-55 mph
DON'T KNOW
  • 2002 FORD F-150
Engine Mechanical problem
2002 Ford F150 V8 86000 miles
My F-150 2002 PU will jerk/hesitate between 40-55 mph. I took it into a garage and they hooked it up to the computer and could not find a current or past problem. I have only had the truck for about 9 months and this just started happening about 2 months ago. I keep the truck in overdrive all the time.
Thursday, June 26th, 2008 AT 10:10 AM
DOCFIXIT
  • 18,828 POSTS
How about driving in Drive and let me know what happens.
Thursday, June 26th, 2008 AT 10:19 AM
DON'T KNOW
I drove it with the overdrive turned off and it did not skip. What does that mean? The overdrive comes on automatically when you start the truck.
Thursday, June 26th, 2008 AT 1:52 PM
DOCFIXIT
  • 18,828 POSTS
There is a switch in the valve the controls fluid flow to the lockup torque coverter. At 45 to 50 it is supposed to lockup and give overdrive. The switches go bad and you feel the jumping in and out of OD. Pan needs to be removed switch replaced.
Hope this helps
Thursday, June 26th, 2008 AT 2:06 PM
