1996 Ford F-150 Daily miss fire #1 cyl.
W C WOOD
  • 1996 FORD F-150
  • V8
  • 4WD
  • 16,000 MILES
I keep getting a miss fire on #1 cyl. I've changed the plug twice, swapped injectors, new wire, new coil pack, and have checked for air leaks. Is it possible that the cotrol module is bad? Or am I missing something. This is a 4.6 engine
Monday, August 2nd, 2010 AT 10:50 AM
  • 109,885 POSTS
Have you checked fuel pump pressure? Also, have you checked for compression in that cylender and for vacuum leaks?
Tuesday, August 3rd, 2010 AT 12:43 AM
W C WOOD
Yes fuel pressure was checked as well as compresion. I'm at a loss.
Tuesday, August 3rd, 2010 AT 7:26 AM
  • 109,885 POSTS
It could be the PCM, but have you checked for an injector pulse to that cylender? Also, if you remove the plug, is it wet, black?
Tuesday, August 3rd, 2010 AT 11:43 AM
W C WOOD
The plug is dry. Can the local dealer check the PCM.
Being the miss is not constant, would they be able to read it. Also I check for the pulse. I think I may loose mine trying to figure this one out.
Wednesday, August 4th, 2010 AT 7:00 AM
  • 109,885 POSTS
A dealer should be able to check the PCM. As far as the plug being dry, if it is not firing, it should be wet unless it's not getting fuel.
As far as the injector pulse, (don't lose yours (lol).
Wednesday, August 4th, 2010 AT 1:49 PM
W C WOOD
I'll have it checked at the local dealer. It will save my pulse, and only give up the rest of my hair. (Lol) thanks for the help this is the first time used this.
Friday, August 6th, 2010 AT 7:43 AM
  • 109,885 POSTS
My hair is about gone too. You should try fixing cars that are thousands of miles away. I can see them, hear them, touch them. It's hard, but I love doing it.
Let me know what you find.
Friday, August 6th, 2010 AT 11:45 PM
