2002 Ford F150 relay
141,000 MILES • V8 • 4WD • AUTOMATIC
CORY836
2002 f 150 lariett supercrew the cruise, auto headlight, and overdrive on the sterring column do not work I checked all fuses and they are fine could it be one of the relays and how do I check that
Jul 10, 2010 at 12:44 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
There is not one single relay that controls these three components together, so I would not see it being a relay at fault. Most likely, it is the wiring on the steering column that may be damaged or loose.
Jul 12, 2010 at 12:06 PM
