2002 Ford F150 OIL LEAK
2002 FORD F-150
85,000 MILES • V8 • 2WD • AUTOMATIC
CHIHUAHUA11
EVERY TIME I CHECK OIL LEVLE IS LOW AND I AD OIL TO PROPER LEVLE DROVE THE TRUCK FOR A WEEK CHECK LEVLE AND IS LOW AGAIN AND HAVE TO PUT MORE OIL I HAVE NO OIL LEAKS UNDER ENGINE HELP PLEASE.
Jul 11, 2010 at 8:32 PM
  • 110,240 POSTS
How many miles in a week do you drive and how much oil do you need to add?
Jul 19, 2010 at 5:34 PM
CHIHUAHUA11
like 80 miles and i have to ad 1/2 qt.
Jul 19, 2010 at 7:36 PM
  • 110,240 POSTS
That is a lot. If there are no leaks, it has to be burning it or mixing into the coolant via a bad head gasket. Is the coolant clean? Also, do you notice any blue smoke from the exhaust? Is there any oil getting into the air filter?
Jul 20, 2010 at 3:01 PM
