2002 Ford F150 Mass air flow sensor
125,000 MILES • 6 CYL • 2WD • MANUAL
WRENCHTURNER
I have the "service engine soon" light on. Diagnostic codes P0171 & P0174 are on and I was told by Autozone the Mass Air flow sensor needs to be replaced.
Do you agree? Do you have a procedure for that?
Dec 27, 2008 at 4:20 AM
BLACKOP555
  • 10,386 POSTS
i agree, but before doing that i would clean off the contacts inside the sensor where the air goes through with qd contact cleaner.
if they get dirty it will throw that code as it isnt reading properly. either that or you have a vaccum leak after.
check those first before replacing the sensor, as the sensor isnt the cheapest thign aroudn.
Dec 30, 2008 at 2:03 AM
