2002 Ford F150 High RPM on cold startup
83,000 MILES • 6 CYL • 2WD • MANUAL
HRYDERIII
Hi
Recently I noticed high RPM upon startup. It is 40 - 50 degrees here now. And also a slight hesitation upon acceleration. I pulled the codes and got P0174. I got some MAF cleaner and sprayed it really good.
The code went away. The hesitation went away. Now I am left with the high upon startup.
Please help.
Harry
Feb 1, 2010 at 11:14 PM
KHLOW2008
  • 41,812 POSTS
Hi hryderiii,
Thank you for the donation.
All modern engines are desigend to run at a higher rpm when the coolant temperature is low so it is normal for the rpm to be higher during cold start. It can range from 1200 to 2000 rpm depending on the temperature and would drop after a short while.
The cleaning of the MAF could have increased the rpm at cold start as it is reading more accurately than it previously was.
What is the cold start rpm now? If it is less than 2000 rpm, then you have nothing to worry about, unless it fails to drop after a short while.
Feb 2, 2010 at 3:28 AM
HRYDERIII
Hi
I think I'm ok. The last cold start at 48 degrees was 2200 rpm for a few 3 to 4 seconds.
Thank you
Harry
Feb 3, 2010 at 10:28 PM
KHLOW2008
  • 41,812 POSTS
You are welcomed and glad to be of service.
Have a great day.
Feb 4, 2010 at 11:12 PM
