2002 Ford F150 Follow up on question truck won't shift put
125,000 MILES • V8 • 4WD • AUTOMATIC
REDSKINSFAN34
I followed the suggestions I got from here yesterday and found the # 15 Fuse was blown. Replaced it and everything was fine for about 30 seconds and the new fuse blew. It seems the interior light overhead is also run off that fuse. Could my problem be at the light? Any suggestions greatly appreciated.
Nov 20, 2008 at 9:45 AM
BMRFIXIT
  • 19,053 POSTS
If you hit replay at the original question will be able to track what is going on without have to go over the whole thing over again
check the cigarette lighter
Nov 20, 2008 at 10:49 AM
REDSKINSFAN34
OK. I did that.
Nov 20, 2008 at 12:25 PM
