2002 Ford F150 Flywheel
124,000 MILES • V8 • 2WD • AUTOMATIC
PSOHAYDA
Recently I had to install a new trans on my 02 f-150. I am trying to finish up but have now encountered a problem where the flywheel will not turn. I can not turn the crankshaft to move the flywheel. How can I fix the issue?
Jun 8, 2009 at 3:34 AM
  • 31,937 POSTS
Hi there,
Is this with the new drive plate attached to the crank or is the engine locked up with out the drive plate attached?
Mark (mhpautos)
Jun 8, 2009 at 11:36 AM
PSOHAYDA
Thanks for getting back to me. I got the flywheel to turn. I had to go through and reinstall the auto trans. Right now I can not seem to get enough power to crank the engine. I am going to try and charge the battery since the truck has sat for two weeks and see if that helps. If it does not though I am out of ideas. So if there is something that you can think of that maybe I overlooked please let me know.
Thanks,
Paul
Jun 12, 2009 at 4:29 AM
  • 31,937 POSTS
Hi there,
Make sure that all the battery. starter & earth connections are tight & clean, have the battery charged 7 load tested as this is the only accurate way of checking the battery condition.
Mark (mhpautos)
Jun 12, 2009 at 12:52 PM
