2002 Ford F150 engine "coughs" about every 1/4 mi
60,000 MILES • 6 CYL • 2WD • AUTOMATIC
LAREBEAR42
My engine light came on 3 weeks ago, but was running just fine. I had light cleared and a vacuum leak repaired. Now the engine "coughs" or cuts out momentarily ( just a second ) and then runs fine for another 1/4 mile or so. Speed does not seem to matter, it just occurs regularly, after the engine warms up slightly and then continues. It feels like a bump in the road to some degree. Otherwise engine runs fine, but I have the feeling something serious is about to happen. Diagnostics by a reputable repair shop does not shoe any indication that anything is wrong.
Dec 22, 2009 at 5:43 PM
  • 31,937 POSTS
Hi there, i would get the fuel injectors serviced, you may have an injector with a sticky pintail, this will not toss a code in the ECU, i would start here.
mark (mhpautos)
Dec 22, 2009 at 6:26 PM
