2002 Ford F150 Driver Side Cylinder Head Replacement
170,000 MILES • V8 • 4WD • AUTOMATIC
TERRASPEED
I need to replace the driver side cylinder head because the #8 spark plug blew out along with the threads. I've located the gasket kit w/ bolts and a replacement head assembly so I don't have to mess with replacing the valves and everything. My main question is do I have to remove the engine to replace this thing or Is it possible to leave the engine in and accomplish this job? I can even take the wheel assembly apart if I need to, that's really no problem. I just don't have the means to pull the engine. Thanks for your help.
Terraspeed
Dec 13, 2009 at 2:53 PM
BIGJIM79
  • 239 POSTS
usually you can raise one side up by loosening the motor mount on that side and putting a piece a wood on a jack and rasing it up.
Dec 13, 2009 at 6:38 PM
