2002 Ford F150 Differential gears
2002 FORD F-150
11,000 MILES • V8 • 2WD • AUTOMATIC
NISSI1982
Can the gears be changed in the differential in the rear?
Aug 3, 2009 at 10:13 AM
  • 31,937 POSTS
Hi there,
You can re build the rear diff but it is a specialist job as the set up and pre load of the bearings and gear sets are precise, more so with a limited slip diff, the crown wheel and pinion are sold as a matched set, spider gears are sold normally as a set as well.
mark (mhpautos)
Aug 3, 2009 at 10:23 AM
