2002 Ford F150 Code P0135
73,000 MILES • V8 • 4WD • AUTOMATIC
PEARHEAD34
Just got a Service Engine Light for my 2002 F-150. (code P0135)
Tells me that I might have a bad oxygen sensor. How easy is this to change and or troubleshoot?
Oct 28, 2009 at 2:21 PM
OBXAUTOMEDIC
  • 3,719 POSTS
O2 Sensors are pretty easy to replace.
They take a special to in most cases and in others a regular wrench is needed.
The code def is
P0135 Oxygen Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
First thing I would check is the wiring on the sensor in question it could be that the wires ended up on the exhaust and melted, shorting it out. Then there are the fuses.
Also the sensor in question I believe is located on the passenger side in the exhaust manifold.
Oct 28, 2009 at 2:34 PM
PEARHEAD34
Where would the fuses be located?
Oct 29, 2009 at 2:09 AM
OBXAUTOMEDIC
  • 3,719 POSTS
Sorry, forgot to tell you were they were.
They are in the underhood fuse block there should be a diagram for there exact location I will see if mithell1 has diagram and post if does.
Oct 29, 2009 at 8:38 AM
