2002 Ford F150 clutch problems
2002 FORD F-150
72,000 MILES • 6 CYL • 2WD • MANUAL
BAMABOY2010
My 2002 Ford F-150 has a leaky slave cylinder. I have been short on cash lately so until I can afford the parts and have the time to pull the transmission, as a bandaid i've just been keeping the master cylinder for clutch full of dot3 brake fluid, and pumping the clutch alot everytime I drive it. This morning when I went to pump the clutch, the pedal sticks to the floor and does not come back to my foot. could I have worn out my clutch cable by pumping it so much? I really have no idea where to start. Please help. thanks alot.
Feb 15, 2010 at 11:58 PM
DOCFIXIT
  • 18,828 POSTS
Hi Slave may have given it up so you can try filling and bleeding. see diagram
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_356.jpg
Good luck Thanks for donate
Feb 16, 2010 at 12:05 AM
BAMABOY2010
Is the bleeder screw located on the bellhousing?
Feb 16, 2010 at 12:08 AM
DOCFIXIT
  • 18,828 POSTS
Yes right above hydraulic line from master
Feb 16, 2010 at 12:48 AM
