1998 Ford 150, 2WD, 4.2
BULL1200
  • 1998 FORD F-150
1998 Ford F150 2wd, 160,000 miles, build date 03-25-1998, 4.2l.
1. Needed a clutch slave, parked it for about a month, running fine when parked. Charged battery, heard clicking sound near fuse panel. Won't start (or hit), runs on ether. Could this be a relay? Which one?
2. With this build date am I ok on the bad 4.2 gasket problem?
Thursday, April 19th, 2007 AT 9:09 AM
MERLIN2021
  • 17,250 POSTS
Could be, I would check the spark, gas, wich I think is you problem, and if all else fails, compression. But since it ran fine a month ago look under the hood for the power distribution box. The fuel pump relay is in there. Let me know if you areen't getting gas.
Thursday, April 19th, 2007 AT 4:16 PM
