2002 Ford F150 Clutch
2002 FORD F-150
50,000 MILES • 6 CYL • 2WD • MANUAL
JASON_APEL
My '02 F-150 is having some problems with the clutch. There is no resistance at all when you push the clutch petal. The truck will start but there is no way to get the clutch into gear. When you try you get grinding. What might this be? I have been told I need a full clutch replacement. How much should that cost?
Jan 28, 2008 at 5:45 AM
MASTERTECHTIM
  • 4,750 POSTS
you might be low on fluid. remove the cover to the clutch master cylinder reservoir and check the fluid level, add brake fluid if it is low then slowly pump the pedal.
Jan 28, 2008 at 5:51 AM
