2002 Ford F150 BAD BREAK LINE
92,000 MILES • 6 CYL • 2WD • AUTOMATIC
GREG S
I need to replace the small piece of rubber hose that is in the brake line. It sits above the front axel and I can not find the parts. It is about a 3 inch peice of rubber hose inserted into a thimble looking connector and then crimped. Is there an after market retro-fit kit or do I use standard steel ine with preasure fittings or what? Any help would be great!
Thanks Greg
Feb 25, 2008 at 4:22 AM
2CARPRO JACK
  • 11,533 POSTS
Im not aware of any repair kit for the rubber lines, usually you have to buy the entire brake line to fix it.
Feb 25, 2008 at 7:26 AM
