HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Climate Control
Blower Fan
Not Working
SPONSORED LINKS
2002 Ford F-150 air conditioner blower motor
JPG13211
MEMBER
2002 FORD F-150
V8
2WD
AUTOMATIC
120,000 MILES
The blower motor stopped, the controls still work, could it be the fan relay switch and where would it be located?
Monday, April 28th, 2008 AT 2:45 PM
BMRFIXIT
MECHANIC
Check fuses and relays check blower motor and wiring
blower motor relay is located in central junction box
SPONSORED LINKS
Monday, April 28th, 2008 AT 5:45 PM
LCFXDL
MEMBER
1 POST
I have the same problem. Have checked the relay iin the junciton box under the hood. It's ok, where is the blower motor located?
Thursday, July 3rd, 2008 AT 2:29 PM
BMRFIXIT
MECHANIC
Under the hood passenger side
firewall
Thursday, July 3rd, 2008 AT 8:33 PM
Please
login
or
register
to post a reply.
Related Blower Fan Not Working Content
Blower Motor Not Working
Electrical Problem V8 Four Wheel Drive Manual 134000 Miles My 2001 F150 Blower Quit Working. Pulled It Out And Hook A Battery Charger...
Asked by
beagleduke9072
9 IMAGES
2001
FORD F-150
1994 Ford F150 Vaccuum ??
Air Conditioning Problem 1994 Ford F150 6 Cyl Two Wheel Drive Automatic Does The Ac Have Some Sort Of A Vaccuum That Affects The Ac...
Asked by
jimmoline
1994
FORD F-150
Blower Fan Just Shut Off
My Blower Fan Stopped Working All At Once I Checked The Fuses And Both Are Good, I Checked For Power With A Volt Meter On The Fan Motor...
Asked by
triton_dc
1998
FORD F-150
Get My Blower Motor Running
What Do I Need To Do To Get My Blower Motor Running When I Turn The Truck On So I Have Heat And Air?
Asked by
manginator
1 ANSWER
11 IMAGES
2003
FORD F-150
Blower Motor Stop Working
Ford F150 2003 On Poower To Blower Motor. I Change The Resistor, Motor, All The Control Module, Fuse And The Relay.
Asked by
traaronmorris
1 IMAGE
2003
FORD F-150
VIEW MORE
SPONSORED LINKS
How to Use a Test Light
How to Replace the A/C Blower Motor
Heater Not Working
Online car repair manuals
