2002 Ford F150 air and truck is missing
138,000 MILES • 6 CYL • 2WD • MANUAL
STEVENEASTTX
i was fixing the license plate light turned the head light switch on and it smoke out the vent above switch i start my truck and the service engine light came on the ac stop working and the motor misses thanks if you can help
Mar 18, 2008 at 10:50 AM
MERLIN2021
  • 17,250 POSTS
First thing you need to do is have the codes read, Autozone does it free, Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored.
Mar 18, 2008 at 11:48 AM
