2002 Ford F-150 2002 Ford F-150 hesitating
SHAWN16
  • 2002 FORD F-150
  • V8
  • 4WD
  • 151,000 MILES
I just had my fuel system cleaned and replaced my fuel filter at Jiffy Lube today, but my truck is still hesitating what else should I do to fix the problem?
Thank you,
Chris
Tuesday, June 15th, 2010 AT 6:49 PM
  • 109,901 POSTS
Chris:
Has the check engine light come on? Have you checked for vacuum leaks and has the fuel pressure been checked?
Wednesday, June 16th, 2010 AT 10:30 PM
SHAWN16
There has been no check engine light, I went ahead yesterday and changed out the spark plugs but now it is running rough with no check engine light, im not sure if it is a bad cop or what?One of the spark plugs I changed out had some stuff melted on the porcline of the spark plug.
Thanks
Thursday, June 17th, 2010 AT 8:25 AM
SHAWN16
I did check for vaccum leaks and found none and I did not check the pressure for the fuel lines.
Thursday, June 17th, 2010 AT 8:28 AM
  • 109,901 POSTS
Did you replace the plug wires? If you found something melted on the porcelain, something tells me the you have a bad plug wire. Also, did you properly gap the plugs? Finally, I would recommend replacing the cap and rotor too.
Friday, June 18th, 2010 AT 11:19 PM
