2002 Ford F150 2002 Clutch Tran problem...local shops cant
2002 FORD F-150
JDKPHOTOS
Transmission problem
2002 Ford F150 6 cyl Four Wheel Drive Manual 100k miles
Helllo
I drive a 2002 Ford F150 4X4 Truck. I have reached a point that I have to be somewhat forceful to get the truck in gear..does not grind or make noise. The truck will not go into gear while truck is stopped, in neutral with the clutch depressed, I have to turn the truck off put it in 1st and then restart to move again. To get around this as I approach a light and slow down I press in the clutch and it will slip into first as I slow down..and have to keep the clutch pressed and in 1st for the duration of the light. My first work around was to not to depress the clutch and just press up against 2nd firmly (not Engaged) and hold it there for at least 30 seconds. Then that allowed me then to hit the clutch and put it in 1st like normal. I also have a hard time getting it to drop into 2nd while in a turn...
Sep 21, 2010 at 8:12 AM
  • 110,244 POSTS
While reading your post, my first thought is the pressure plate is bad or weak. Do you ever get any chattering from the clutch when you pull out from a stop? Also, is the clutch fluid full?
Sep 21, 2010 at 3:05 PM
JDKPHOTOS
Hey Guys
No sorry I never have heard any chatter and the clutch fluid is full..
Thank you
James
Sep 21, 2010 at 5:42 PM
  • 110,244 POSTS
James,
Based on that, I would lean toward the a bad or weak pressure plate that isn't full disengaging the engine and trans.
Sep 22, 2010 at 6:02 AM
JDKPHOTOS
Thank you!!!!
Sep 22, 2010 at 7:53 AM
  • 110,244 POSTS
First, I'm sorry for the delay in getting back to you. I lost my father this week, so I have been tired, depressed... I hope you understand.
As far as the clutch, I'm happy to help. Let me know what you find.
Sep 24, 2010 at 3:47 PM
